Kältemittel C6
suche mir gerade nen Wolf in der Suchfunktion  Kopfschütteln Da frage ich mal lieber direkt. Wieviel Kältemittel und Öl bracht die Klimaanlage meiner C6 LS2??
Walter
Prost!
Aus der BA
Die korrekte Füllmenge für das Klimaanlagenkältemittel ist dem Kältemittelaufkleber unter der Motorhaube
zu entnehmen. Weitere Informationen erhalten Sie von
Ihrem Händler.
Oder hier: https://shop.advanceautoparts.com/find/c...t-capacity
500 Gramm
und 10g Öl
Corvetteproject
Telefon     02406 9247240
Öffnungszeiten Mo-Fr
(01.04.2021, 14:17)Molle schrieb: 500 Gramm
und 10g Öl
Werner hat mal wieder recht, in meiner C6 aus 2005 habe ich einen Aufkleber der sagt 640 Gramm. ein Jahr später kam dann eine TSB und die sagt 500 Gramm.
Subject: Poor A/C Performance in Elevated Ambient Conditions - keyword charge cool HVAC leak temperature #PIC3598 - (07/01/2005)
Models: 2004-2005 Cadillac XLR
2005-2006 Chevrolet Corvette
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Customers may bring in their vehicle with complaints of the air conditioning suddenly blowing hot and moist air on occasion. They may also say that the blower speed is going up and down at the same time. This can happen whether the system is in automatic or manual modes. It is likely that the vehicle will pass the standard service manual A/C diagnosis, and the dealership unfortunately has to tell the customer that there is no trouble found.
The system is experiencing a high head pressure situation. The engine control module will disengage the compressor clutch at pressures above 300 kPa (435 psi) for safety. Any time the compressor is off, the HVAC control head will return the system to outside air from recirculation mode to reduce interior cabin noise, unless the customer has manually selected recirculation mode. The sound level difference is often mistaken for a change in blower speed.
This condition is most likely seen on a hot engine re-start such as after a gas station stop, prolonged low speed driving, or vehicle idling at an elevated ambient condition. The initial spike in head pressure may be enough to disengage the compressor clutch. If the vehicle has any forward motion, the system will recover within seconds. If the vehicle is stationary or in a significant tail wind, the system can take minutes to recover after a disengagement.
Recommendation/Instructions:
After verifying that the vehicle's refrigerant pressure sensor is working properly, the solution is to reduce the refrigerant charge level from 0.64 kg (1.4 lbs.) to a new charge of 0.50 kg (1.10 lbs). Bowling Green Assembly Plant has begun to charge all of its vehicles to 0.50 kg (1.10 lbs). Recent vehicle testing has confirmed the effectiveness of this solution. The air conditioning cooling capacity is not affected. New charge labels will be available at a later date.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Callaway Honker
Ported throttle body
Ported intake
Crane Cams 1.8 ratio rockers
Kooks Jet Hot coated headers
Callaway Competition Shocks
Hotchkis sway bars
Diablosport Trinity with custom tune
Brian Tooley Racing valve spring kit
und wie lauten die Werte für die LS3 ab 2008 ?
2008 C6 LS3 Cabrio  -  rot, rotes Leder, schwarzes Verdeck     US-Modell
1988 C4 L99 Cabrio  -  rot, rotes Leder, schwarzes Verdeck        1. Besitz
1988 C4 L98 Cabrio  -  weiß, schwarzes Leder, weißes Verdeck  2. Besitz
fährt über 50 Jahre amerikanische Autos
fährt über 45 Jahre Corvette
Danke Euch!! Dann kann ich zum Klimaservice.
Walter
Prost!
