Reifen
Zitat:Original von chrisV8
Taugen diese Reifen was oder sind die eher nix,billig sind sie ja Schnarchen
The Exclaim UHP is General Tire's Ultra High Performance Summer tire that was developed for the drivers of sports cars, coupes and sedans. While meeting minimum tread design Standards to be "M+S" branded, the Exclaim UHP is designed to provide high levels of traction, response and control in dry conditions, along with superior hydroplaning resistance in wet conditions. We do not suggest Exclaim UHP tires be driven in near-freezing temperatures, through snow or on ice.
The Exclaim UHP uses a 2nd generation, ultra high performance silica compound molded into a directional tread design that features wide, solid shoulder tread blocks and a high-tech contour to combine responsive handling with dry traction. Its Double-V directional tread pattern enhances wet performance. Together, the tread compound and design help sweep water away from between the tire’s contact patch and the road to improve wet grip while reducing the possibility of hydroplaning. The tire’s internal structure includes twin steel belts reinforced by spirally wound jointless nylon on top of polyester body plies to combine responsive handling and cornering stability with high-speed durability.
General Exclaim UHP (Ultra High Performance Summer)
for 2006 Chevrolet Corvette Z06
Front: 275/35ZR18
Blackwall
Serv. Desc: 95W
UTQG: Treadwear: 380
Traction: A
Temperature: A380 A A
Price: $169.00 (each)
Estimated Availability:
In Stock
Optional Road Hazard Program: additional $20.28 per tire
Front:
012345678
Rear: 325/30ZR19
Load Range: XL
Blackwall
Serv. Desc: 105W
Traction: A
Price: $203.00 (each)
In Stock
Wo würdest Du die beziehen? In Deutschland? Ich hätte Interesse an den Reifen!
Hallo Alex
Hier https://www.tirerack.com/tires/TireSearc...ed_rating=(Y)&RunFlat=All&loadRank=1
Gruss Chris
[Bild: gtc17.gif]
Die Hoosiers sind ja ein Traum! Yeeah! Teufel King
Hast bei denen schon mal bestellt? Liefern die nach D, oder wie hättest du das gemacht?
Hi Alex
Habe da noch nichts bestellt,ob die nach D liefern,keine Ahnung
Gruss Chris
[Bild: gtc17.gif]
  Reifen 18/19 Zoll Z06/GS - Stand 6/2025 colonel 2 872 08.07.2025, 17:50
Letzter Beitrag: ace
  Reifen in 19/20" für die C6 Z06 sto 12 4.505 08.07.2024, 21:22
Letzter Beitrag: sto
  Alternative C6 Z06 Reifen chevyman 292 207.719 20.07.2023, 21:34
Letzter Beitrag: vladiiiii
  Reifen aufziehen 335/25 R20 in Frankfurt/Darmstadt/Wiesbaden oder Umgebung Chiado 12 27.360 30.09.2021, 16:04
  C6 Z06 Reifen Mad11 67 40.245 04.02.2017, 12:26
Letzter Beitrag: corvettetotal
