Z06 Artikel mit Bildern
Hat mal jemand die richtigen lottozahlen Frage Hilfe!!
würde mir gerne das tolle teil zulegen Yeeah!
bin aber leider von Ullalala Schmidt abhängig Zum K....n
wie sieht es mit einer kleinen spende zu weihnachten aus huldigen
habt ein Herz
ein schlafloser günni Geist
frohe weihnachten und ein spannendes z06 jahr Hallo
[Bild: Berge.jpg]
Zitat:Original von Ray8
Möge der Dollarkurs bis April 06 noch KRÄFTIG steigen.... Feixen
Grüße und merry xmas,
Bernd
Wäre es nicht besser wenn er fällt,bzw der EURO steigt?
Weihnachtliche Grüsse
John
V8, the american way
Hallo Leute, nachfolgend das Wichtigste aus dem Artikel in CORVETTE MAGAZINE von Januar 2005! Großes Grinsen
[Bild: z06vettemag5sm2mw.jpg]
Zitat:The 2006 Z06 is constructed around a perimeter-style frame just like other Corvettes, but the main rails beneath it are hydroformed out of aluminum instead of steel. The front engine cradle on the street car is made of lightweight and robust magnesium. And where the final year of the old Z06 included a carbon-fiber hood largely for commemorative-edition fanfare, the new Z06 takes advantage of that exercise by including carbon-fiber front fenders and wheelhouses plus sheet-carbon floorboards surrounding the model's traditional balsa-wood core. There's a lightweight, non-removable magnesium roof panel that simultaneously lower the Cg and greatly increases rigidity. And despite the addition of numerous beefier, heavier performance components such as larger brakes, heavier antiroll bars, and wider wheels, the 2006 Z06 weighs nearly 50 pounds less than the standard C6 (or some 3130 total) thanks to the extensive use of advanced chassis and body materials.
On the outside, the Z06 body includes several visual updates to separate this FIA stalking horse from the cooking C6. The more obvious changes include a central hood intake, flared wheelarches stretching a full three inches wider than standard, cooling ducts for the rear brakes, stouter front-fender vents, and reworked nose and tail caps. It's a relatively short list of differences, but the changes are substantial enough to ensure that the new Z06 stands out even more than the much loved C5 version. On the inside, unique lighter, grippier leather seats are joined by a smaller and much more attractive three-spoke wheel, standard HUD and air conditioning, and reduced sound insulation.
Still, like its predecessor, the majority of the upgrades have taken place underneath, starting as always in the engine compartment. Followers of the C5R racing effort are well aware of that car's potent powerplant, a bored-and-stroked interpretation of the familiar Gen-III V8. With a huge 4.125-inch bore and four-inch stroke giving a Rat-sized 427 inches of displacement, the "smallblock" designation was somewhat of a misnomer for that engine, even though it retained the same external dimensions as its LS1/LS6 forebears.
That same 427 is slated to continue in the C6R, but thanks to the much closer relationship between road and race trim demanded by new FIA/ACO/ALMS rules, the roadgoing Z06 will get its own 427 (Mat-motor? Rouse-motor?) for 2006. The numbers are nothing short of staggering: a full 500 horses at 6200 rpm, 475 lbs-ft @ 4800, a sub-four 0-60 dash, and quarter-mile sprints in under 12 seconds—a set of bogus plates and a false identity card would be nice additions to the glovebox. Despite being essentially a re-thought race motor, this new Z06 mill (called LS7 by GM) also promises remarkable tractability, thanks to receiving the same level of engine-management attention given its junior cousins.
While its exterior dimensions and general layout are shared with the LS2, the new LS7 is based on a separate block casting and assembled by hand at GM's new Performance Build Center in Wixom MI. The punched-out aluminum block carries lightweight titanium conrods attached to aluminum flat-top pistons giving 11.0:1 compression. Six-bolt, CNC-machined, forged-steel main caps are needed to keep the assembly together.
CNC machining is also utilized on the new aluminum heads, which boast an 18% improvement in airflow over LS2 units. Nearly straight tunnel-like intake runners feed the air/fuel charge through huge 2.2-inch titanium intake valves while 1.62-inch, sodium-filled hollow exhaust valves let spent gasses back out. A hydraulic-roller cam provides a significant .591-inch lift, even before taking into account the super-high-ratio rocker arms.
As on the C6R's race engine, hydroformed four-into-one tubular headers carry the exhaust from the heads, after which it's routed into a model-unique set of catalytic converters and dual-mode mufflers. The latter include a vacuum-operated valve that stays closed at low revs to manage noise and opens at larger throttle angles for minimum backpressure. The engine is lubricated by racing-style dry-sump oiling, which ensures complete lubrication under all cornering loads. Despite the massive displacement, lightweight internals give the LS7 a 7000-rpm redline in roadgoing trim—a figure more commonly associated with multivalve twincam Fours than traditional pushrod V8s.
The LS7's significant output is channeled through a lightweight flywheel and clutch assembly feeding a strengthened version of the previous model's Tremec six-speed transaxle. This rear-mounted gearbox includes a pump that routes transmission fluid through the front radiator stack for additional cooling, after which the chilled fluid is also used to help cool the lubricant in the limited-slip diff on the way back. The latter unit features an enlarged ring-and-pinion assembly and turns upgraded halfshafts and U-joints.
Huge 325/30ZR19 rear Goodyears put the power to the ground; the matching Eagle F1 Supercars up front are 275/35ZR18s. These ride on Z06-specific split-spoke alloys measuring 18x9.5 front and an imposing 19x12 at the rear. The basic suspension layout is shared with the standard Corvette, but performance-directed upsizing of the spring rates, antiroll-bar diameters, and braking hardware sets the Z06 apart. The stopping is done by 14-inch vented and crossdrilled rotors up front and 13.4-inch pieces out back, an increase of more than an inch at both ends. New six-piston calipers in front and four-piston units in back handle the clamping needs.
Corvette enthusiasts will undoubtedly applaud the comprehensive component list associated with the new Z06, but all that hardware is certain to come with a price. While the previous Z06 was able to hit showroom floors with a very digestible sticker thanks to its focus on just a few well-placed modifications, the more complete package that comes with the C6 version will inevitably equate to a tougher-to-swallow tariff.
[Bild: party.gif]
1992 C4, 2003 C5, 2003 C5 Convertible, 2006 C6 Z06 - alle verkauft  Kopfschütteln
Hat schon jemand gelesen, ob auch eine Cabrio-Variante geplant ist?
Hallo Frank,
wenn schon die Targa-Variante aus Steifigkeitsgründen dem fest verankerten Dach zum Opfer gefallen ist, dürfte eine Cabrio-Variante eher unwahrscheinlich sein.
mit noch weihnachtlichem Gruß
More News gibt's in Car and Driver 02/05. Prost!
[Bild: C6-Z06_page1.jpg]
[Bild: C6-Z06_page2.jpg]
[Bild: C6-Z06_page3.jpg]
huahua Yeeah! Burnout
Zitat:and these are SAE net horses, not the bogus gross ponies from the '60s
sich vor Lachen auf dem Boden wälzen sich vor Lachen auf dem Boden wälzen sich vor Lachen auf dem Boden wälzen
Der ist wirklich nicht schlecht Dafür
Gruss Beat
Ist dieses Spion-Bild der C6R schon bekannt?
Jetzt ja.
Sind eigentlich schon genaue Daten bekannt?
animierte C4 bow TieVetteFlo :
  TIKT Sitze C6 Z06 mit CH-MFK Zmaster 15 6.868 30.10.2022, 14:30
  Navi Umbau auf Doppeldin Icartech Alpha S700-mit Rückfahrkamera-TV-DAB-DVR -- mit Bilder! ratz8888 0 6.832 08.06.2014, 18:26
Letzter Beitrag: ratz8888
  C6 mit Z06 Felgen -> Reifengröße? menix 23 14.254 17.02.2013, 20:13
Letzter Beitrag: menix
  Unterschied Z06 zu Z06 Performance Package Wollo8 3 5.545 12.05.2012, 19:48
  Erfahrungen mit Cobalt XR2 fuer Z06/GS BigMP 0 2.465 14.04.2012, 22:37
Letzter Beitrag: BigMP
