www.corvettelemans.com
Hi Ares,
danke Yeeah!. Läuft gut, aber momentan F1 auf Wheels Heulen.
Tom
von mir auch danke !
.... Gott sei dank........ King Schnuller
@Hape
Läuft bei Dir denn LeMans Grübeln?
Das ist ja obergeil ! Danke Ares !
Momentan läuft zwar Nascar (Tick, Trick und) Truck-Rennen, aber I stay tuned, gyus OK!
Take care, ...
Zitat:D.N.F. 64 Corvette Racing LMGT1 BERETTA O OUT
Heulen
Zitat:10 007 Aston Martin Racing LMGT1 HERBERT J 83 19.266 3:54.889 3:52.486 Run 8
11 33 Barazi Epsilon LMP2 FERNANDEZ A 83 35.073 5:32.346 3:41.916 Run 8
12 009 Aston Martin Racing LMGT1 RYDELL R 82 8 Laps 4:50.741 3:52.326 Run 7
13 40 Quifel ASM Team LMP2 DE CASTRO MA 82 31.207 3:52.660 3:44.993 Run 1
14 63 Corvette Racing LMGT1 FELLOWS R 82 1:39.150 3:54.762 3:54.747 Run 8
OK! OK! OK! OK! OK! OK! OK! Daumen drücken !
Hallo-gruen , ....
Bin gerade heimgekommen und guck das jetzt auf MotorsTV, bis ich schiele.
JR.
https://www.badboyvette.com/main/main.php
Zitat:The #64 Corvette C6.R has retired from the Le Mans race due to a failed driveshaft.
Because the starter motor is positioned after the driveshaft, the car was still able to move under its own power and would have been able to limp back to the pits (that's why you saw it start to leave on TV), but recent Le Mans rule changes have made it illegal to do so.
"Oliver Gavin, the driver of the now retired No.64 Corvette Racing Corvette C6.R, reports that their retirement was caused by the failure of the carbon-fiber prop shaft. He believes it was shaken to bits while he was behind the safety car. Under the control of the safety car, the Corvette Racing C6.Rs are using a special fuel saving mode which cuts out a number of cylinders. This appears to have caused a vibration which caused damage to the prop shaft."
Heulen Heulen Heulen
1992 C4, 2003 C5, 2003 C5 Convertible, 2006 C6 Z06 - alle verkauft  Kopfschütteln
und ich schiele schon von der Tabelle jürgen.....
da ja auch "wheels" die ganze zeit nur pickl-aps im kreis fahren lässt....
besoffen
Hape, jetzt aber wieder .....
Hallo-gruen , ....
wird auch zeit.... besoffen
die "63 ist wenigstens noch auf 3 in der gleichen runde wie die beiden AM
