Jack aus Maine möchte mit seiner 66er C2 Europa bereisen - Tipps?
haarsträubend haarsträubend haarsträubend Hi Jack. Are you safe of Juno? We heard it is a terrible blizzard runing over NY, Maine and the east coast. I hope you and your family are safe in a warm livingroom.!! Blume The next spring will come...
Greets Dieter Patriot
[Bild: osc_logo_klein.gif] [Bild: DieterBanner.jpg]
OK! take it easy, but take it OK!
Gary Ramadei is working on the rear end and I should have it by late April. (Great Rear End Man) lol
What started as a stuck plug has changed into a Under body restoration.
First the plug would not come out, then the rear end blew, and before you know it project creep.
Well I finally got the plug out. I had to remove the welded muffler pipe and header pipe, and after many failed attempts, I used an Irwin stripped bolt remover socket. I heated the plug, I put penetrate on it, I froze it.
I had to remove the pipe to be able to hammer on the socket, once on, I could use the long ratchet to remove it. Out it came see photos.
The #4 body mount bolt is the one that has me working hard.
Got the parts out of car
[Bild: IMG_2722_zpseolrhtgg.jpg]
Car ready for additional work
[Bild: IMG_4559_zpsebor8azp.jpg]
Seats have to go
[Bild: IMG_4560_zpsulxegwbi.jpg]
[Bild: IMG_4564_zpsvqu6wdrh.jpg]
Here I go..and it came out
[Bild: IMG_4566_zpshk3ggvyz.jpg]
See the plug and socket
[Bild: IMG_4565_zps2u2vpx3h.jpg]
[Bild: IMG_4569_zpsgomrkwrl.jpg]
Now fun with # 4 body mount
[Bild: IMG_4562_zpssydfdzft.jpg]
[Bild: IMG_4563_zpsot9h8nd0.jpg]
Cleaned up a bit
[Bild: IMG_4571_zpsc7gb4vxb.jpg]
Join the Corvette Vagabond Community
Like me on Facebook
Follow me on Twitter
My website
Hello to all,
We left off with the bolts soaking and all the rubber peeled away on # 4 mount.
I went out this afternoon to soak the bolts again and while there I picked a bit at the bushing sleeve and bolt.
I decided to give the bolt a little bit of a turn. The result, the bolt came out with the nut . The nut capture cage is not rusted , but the frame mount and and mount reinforcement was rusted, one turn and out it popped.
I will let you all give me advice on what to do next. I do not weld !
Mount with rubber still on it
[Bild: 4%20mount%20rubber_zpsdc0dywpt.jpg]
Bolt and nut with bushing sleeve
[Bild: Bolt%20Nut_zpso2eqy30z.jpg]
Frame mount and nut cage
[Bild: 4%20frame%20mount_zpsbhf6w354.jpg]
Side view
[Bild: 4%20mount%20side_zpsm06gg195.jpg]
Like me on Facebook
My website
Hi Jack,
know this place of the car too.
Don´t want to know how many doesn´t.
[Bild: 21315265wz.jpg]
Good Luck Hallo-gruen , ...........
I went out to the garage , forgot to change my clothes, I was just going to spray a little more penetrate on the bolt holding the reinforcement plate.
Well I could not resist putting a ratchet to the bolt. I forgot to take the deck off and just reached in . It took a while to get the right extractor socket on the bolt . 9/16 to big , 1/2 to small. You must be able to hammer the socket on to really get them to work.
After 10 minutes, I put my big wrench to it. The one that I am always told not use. Well one click at a time the bolt came out. It took about 20 minutes to get it out, not hard , just one little click because of the tight space.
I was them able to remove the rusted mount reinforcement plate . Once removed , I will be able to put a small piece of fiberglass over the hole to hold the nut in the cage. The cage was not rusted . The new reinforcement plate for the # 4 mount will secure the bushing to the body.
I will then be able to fabricate a retaining plate for the # 4 frame mount which had a rusted out hole. The mount is good. I will get the plate welded to the mount once I have the car on the road.
I was very fortunate to not have a rusted out deck hinge area. All the rust was in the wheel well, except for the retainer bolt. It was only a few inches away from the rusted bushing.....
Here are the photos
Ratchet in place with a little hammer to hit socket on to bolt
[Bild: %204%20mount%20socket%20extract_zps3ybfayff.jpg]
View of position of extraction
[Bild: %204%20mount%20extraction_zpsllwjultm.jpg]
The rusted plate # 4
[Bild: %204%20mount%20rusted%20plate%201_zpsxtndjgjw.jpg]
49 year old bolt with very little rust
[Bild: %204%20Mounting%20bolt_zpsovsevxtw.jpg]
The old bushing and plate
[Bild: %204%20bushing%20-%20reinforcement_zpseqvhngsx.jpg]
# 4 mount after clean up
[Bild: %204%20Mount%20view%20clean_zpsggfm3owp.jpg]
Close up of nut and cage - rivets still holding it in with very little rust
[Bild: %204%20Clean%20view%20c_zpsdtim5ztu.jpg]
View from below of mount
[Bild: %204%20Clean%20view%20d_zps5rtphuvx.jpg]
Like me on Facebook
My website
Jack
German car manufacturers take cars with high troublefree milages back and refund the owner with a new current Modell. You should contact Bowling Green and ask for their comments to this.
Your Vette is a Celebrity on ist own and worth to be exhibited. Including tear and wear and your seat covers.
Good Luck
6TVette Patriot
[Bild: signatur_6Tvette.jpg]
As you all know, this started out as a stuck plug on my tranny. Well the rear end blew and I got a chance to take the rear down to Gary Ramadei, in New Haven CT. He is one of the best re-builders in the country.
He did my steering box and now the rear.
Here are the photos of Gary at work doing a preliminary inspection of my rear. As you know, it was a mess after blowing up a few months ago.
The posi unit would not come out even with the side yokes removed. Gary will use a case spreader later in week to spread the side walls of case so that the bearings and posi can be removed. We tried with a pry bar but could only get it half way out.
I will have follow up photos as Gary sends them to me next week.
The end result will be a rear that will go from 3:70 back to the original 3:36 that the car was born with.
The arrival
[Bild: 1Lifting%20off%20cart_zpsmqrqg7cr.jpg]
Proper mounting needed to work on rear
[Bild: 3mounted_zpscvkhwdke.jpg]
Cover is off and that look is not good !
[Bild: What%20happen_zps6fwbkx2t.jpg]
You expect me to fix this ?
[Bild: 4One%20look%20inside_zpssk8j49td.jpg]
[Bild: 5taking%20capes%20off_zpsafr575k6.jpg]
Oh my ! what do we have here ?
[Bild: Not%20pretty_zpsmeamvuje.jpg]
Need a big wrench to turn the unit to get at snap rings
[Bild: Big%20wrench_zpspgjpk7fk.jpg]
Got them off after a bit of work
[Bild: 5snap%20ring%20off_zpsspki7yfb.jpg]
Pry Bar did not work
[Bild: Pry%20bar_zps8npgobit.jpg]
Needed a big hammer to get the side yokes to come out, usually they side right out but the case is a little twinkled
[Bild: 7Big%20Hammer_zpsfrquyl7i.jpg]
Side yokes removed
[Bild: Iphone%20all%20390_zpswcnebtp0.jpg]
Like me on Facebook
My website
I have been fortunate to own the car for 45 of it's 49 years. 46,000 miles on it when I bought it from original owner. Now pushing 300,000 and 4 restorations, visits to 48 states and 15 European countries.
Not bad for an old sports car
Jack
[Bild: FirstSnow2012001.jpg]
Like me on Facebook
My website
Not bad for an o.. No: not bad for a real Vette-Owner Großes Grinsen
Hy Jack,
Your car is really great. It was a good experience
Driving it as we met last time!
Liebe Grüße von Markstingray
  Problem mit UPS / Paket aus USA Chevyvette90 17 16.435 14.09.2021, 11:23
Letzter Beitrag: Tim11
  Actioncam fürs schnelle fahren ... Tipps und Erfahrungen gesucht knork 7 8.005 14.06.2018, 23:59
Letzter Beitrag: knork
  C6 60th Anniversary Modelle (2013) für Europa?? CheviBert 19 12.202 21.02.2018, 22:55
Letzter Beitrag: P.A.J.
  Tipps zum Überwintern der Vette Peter/Hamburg 33 29.081 04.12.2017, 10:18
Letzter Beitrag: Carpat
  Erfahrungen mit Vollkasko mit Werkstattbindung Pauli 14 10.332 05.10.2016, 14:14
Letzter Beitrag: Pragmatiker
